[QGIS-trac] Re: [Quantum GIS] #1531: Georeferencer GDAL crashes QGIS
Quantum GIS qgis at qgis.org
Mon Jul 13 06:31:30 EDT 2009
        Reporter:  hdus                                       |         Owner:  gislab
            Type:  bug                                        |        Status:  new
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.0.3
       Component:  Plugins                                    |       Version:  HEAD
      Resolution:                                             |      Keywords:
Platform_version:                                             |      Platform:  Debian
        Must_fix:  No                                         |   Status_info:  0
Changes (by lutra):
 * cc: pcav (added)
Comment:
 I'm not able to reproduce the problem, also probably because I'm not
 understanding very well the description.
 If you select "polynomial 2" you need at least 6 points. If you select
 less, qgis warns you and do not let you make the transformation. It takes
 a while to produce the transformed image but eventually it makes it.
 I don't see any particular problem when I open a new image to georeference
 or if I open the same (qgis warns you that a world file already exist).
 Please give further feedback.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1531#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
