[QGIS-trac] Re: [Quantum GIS] #1417: Unable to add a Postgis layer
when the key attribut have an alias
Quantum GIS
qgis at qgis.org
Mon Jul 13 14:08:14 EDT 2009
#1417: Unable to add a Postgis layer when the key attribut have an alias
Reporter: mgrizonnet | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.3
Component: Data Provider | Version: HEAD
Resolution: | Keywords: postgis layer/primary key/alias
Platform_version: | Platform: Windows
Must_fix: No | Status_info: 0
Comment (by pcav):
Just tested with:
mipi=> create view view1 as select cat, the_geom from fix where cat=2531;
CREATE VIEW
mipi=> create view view2 as select cat as id, the_geom from fix where
cat=2531;
CREATE VIEW
and QGIS can load both layers without hassle: can you please check again
and report back?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1417#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
