[QGIS-trac] [Quantum GIS] #1780: Lables: Data defined position from
geometry column
Quantum GIS
qgis at qgis.org
Wed Jul 15 04:11:12 EDT 2009
#1780: Lables: Data defined position from geometry column
Reporter: mwtoews | Owner: nobody
Type: enhancement | Status: new
Priority: minor: annoyance or enhancement | Milestone:
Component: MapCanvas | Version: HEAD
Keywords: | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
I would like to use a geometry (POINT) attribute to position label, using
the example postgres schema:
CREATE TABLE region
gid serial NOT NULL,
geometry geometry, -- SELECT
AddGeometryColumn('public','region','geometry',26910,'POLYGON',2);
label geometry, -- SELECT
AddGeometryColumn('public','region','label',26910,'POINT',2);
Here, there are two geometry columns: a polygon for the shape in the map,
and a point to specify and store the label location.
The present versions (1.0.1 to 1.2.0 unstable) support X/Y coordinates
from two numeric columns. (This is found in Layer Properties > Labels >
Data defined position).
The enchantment requested in this ticket is to add another pull-down for a
data defined position, which would be a geometry column. This seems more
natural than defining two numeric columns for X and Y coordinates.
I suggest first keeping it simple, supporting only POINT geometries.
However, I can also envision enabling MULTIPOINT (for multiple places of
the same label), and perhapps [MULTI]LINESTRING for text along a path
(creeks, rivers) if the text fits the length. Furthermore, the centroid
can easily be extracted from all other geometry types ([MULTI]POLYGONs,
COLLECTIONs, etc.) to represent the coordinate for the label (i.e., this
is the "else"/"default" case for other geometry types).
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1780>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
