[QGIS-trac] Re: [Quantum GIS] #1680: New GRASS shell does not
display command gui
Quantum GIS
qgis at qgis.org
Wed Jul 15 05:28:34 EDT 2009
#1680: New GRASS shell does not display command gui
Reporter: cgsbob | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone:
Component: GRASS | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Changes (by pcav):
* platform: Debian => All
Comment:
This is not what grass-qgis plugin was made for: the idea here is to
present the user with a simplified set of options. In case you need more
flexibility, we can always write a more complex module, with all the
parameters to be filled (or with pre-set options).
Having the full GUI of grass does not make sense here: if you want to use
the grass GUI you better use grass directly. Furthermore, in this case
QGIS would also depend on a whole lot of other software, which would make
packaging (especially for windows) much more difficult.
I suggest you to fill wishes for the commands for which you want more
options available, and we can try to write them.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1680#comment:6>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
