[QGIS-trac] Re: [Quantum GIS] #1685: Print composer does not work
Quantum GIS qgis at qgis.org
Wed Jul 15 09:58:27 EDT 2009
        Reporter:  vince                             |         Owner:  nobody
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:
       Component:  Printing                          |       Version:  HEAD
      Resolution:  fixed                             |      Keywords:  Print composer
Platform_version:                                    |      Platform:  OS X
        Must_fix:  No                                |   Status_info:  0
Changes (by lutra):
 * cc: pcav (added)
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:10 simonb]:
 > Testing with OS X 10.5.7 and Qgis 1.1.0-Pan (Unstable) installed from
 http://www.kyngchaos.com/files/software/unixport/Qgis-1.1.0-3-Leopard.dmg.
 > Works for me, although the "Composer Item Properties" and "Map Extent"
 widgets are crushed to unreadability for certain object types unless the
 Print Composer dialog window is expanded from initial default size. See
 screenshot "Print Composer Widgets.png"
 this is a problem that is common to the other platforms, and depends also
 by the size of the font used in your desktop environment. I close this
 ticket because the original problem seems to be resolved. I'll check if a
 ticket has already been filed about the readability problems in the
 composer.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1685#comment:11>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
