[QGIS-trac] Re: [Quantum GIS] #1290: Shapefile attribute tables do not show lines with null geometry
Quantum GIS qgis at qgis.org
Thu Jul 16 12:30:12 EDT 2009
        Reporter:  gabrimonfa                        |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.0.3
       Component:  OGR Layer support                 |       Version:  HEAD
      Resolution:                                    |      Keywords:  shapefile, null geometry
Platform_version:                                    |      Platform:  Unix
        Must_fix:  No                                |   Status_info:  0
Comment (by lutra):
 I had the chance to try both the shapes you posted also on arcview 3.x and
 arcgis 9.x
 On arcview 3.x they load fine and attribute tables show the records
 correctly. Arcgis 9.x works differently: in the first case it gives first
 a "general function failure" and then, when you open the table, a "error
 getting a list of OIDs from the table" and shows nothing. In the second
 case Arcgis 3.x gives directly a "error loading feature class" and do not
 load the shape.
 On the other hand gvSIG seems to open correctly the table.
 In what situations do you use such shapefiles? Maybe do you digitize at a
 later time a vector and then attach it to the table?
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1290#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
