[QGIS-trac] Re: [Quantum GIS] #1718: Incorrect unique key
interpretation on PostGIS view - view doesn't load as expected
Quantum GIS
qgis at qgis.org
Sat Jul 18 13:37:40 EDT 2009
#1718: Incorrect unique key interpretation on PostGIS view - view doesn't load as
expected
Reporter: mwtoews | Owner: nobody
Type: bug | Status: new
Priority: minor: annoyance | Milestone: Version 1.2.0
Component: Data Provider | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Changes (by pcav):
* priority: major: does not work as expected => minor: annoyance
* platform: Windows => All
* milestone: Version 1.0.3 => Version 1.2.0
Comment:
It seems that the problem lies in using both table aliases AND column
aliases; if you use only one of the two, the problem disappears.
CREATE OR REPLACE VIEW spot_analysis AS
SELECT ana.sid, spt.geometry, spt.id AS spot_id, smp.sid AS sample_sid,
ana.parameter, ana.result
FROM spot spt
JOIN sample smp ON spt.id::text = smp.spot_id::text
JOIN analysis ana ON smp.sid = ana.sample_sid;
How do other clients behave in such a case?
Aha, more info: the problem seems to depend on aliases in primary keys.
With OIDs as primary key the problem seems to disappear.
Probably #1417 is a duplicate of this.
Thanks Emilia Venturato for tracking it down.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1718#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
