[QGIS-trac] Re: [Quantum GIS] #1647: Import Inkscape SVG drawing into Print Composer
Quantum GIS qgis at qgis.org
Sun Jul 19 07:00:32 EDT 2009
        Reporter:  craigleat         |         Owner:  nobody
            Type:  enhancement       |        Status:  closed
        Priority:  minor: annoyance  |     Milestone:  Version 1.2.0
       Component:  Printing          |       Version:  HEAD
      Resolution:  fixed             |      Keywords:
Platform_version:                    |      Platform:  All
        Must_fix:  No                |   Status_info:  0
Comment (by neumann):
 Well - as I stated above there are problem with text.
 Multiline text often fails to import correctly. There are two possible
 solutions (outside of QGIS):
 * Fix the import problems in QT (I believe that's the desired route)
 * Fix the Inkscape export - which is theoretically standards compliant -
 but a bit awkward as it outputs everything in styles and uses strange
 repeated/redundant style and placement attributes. Once the attributes are
 cleaned up manuall, QGIS importst the SVGs fine
 I would recommend fixing both issues - but it is somehow outside the scope
 of QGIS. So I guess we can really close this bug. It's probably not solved
 but it can't be solved in QGIS directly.
 We should knock on Nokia/Trolltech and Inkscape door to get this fixed.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1647#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
