[QGIS-trac] Re: [Quantum GIS] #1433: measurements and scale broken
in latlon
Quantum GIS
qgis at qgis.org
Mon Jul 20 06:03:15 EDT 2009
#1433: measurements and scale broken in latlon
Reporter: msieczka | Owner: timlinux
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.2.0
Component: Projection Support | Version: HEAD
Resolution: | Keywords: scale, projections, measure line, measure area
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Comment (by cfarmer):
Replying to [comment:6 borysiasty]:
> This is an important issue. Many users think the unit selector allows
some kind of reprojection in the fly and feel confused.
I agree, this is an important issue, and once a clear plan of action in
set in place, likely won't take long to fix...
> Shouldn't we tie the units to the current CRS and take the selector
away? Actually it's partially implemented: if I set the project CRS to any
metric one and OTFR is enabled, the units are switched to meters
automagically. But if OTFR is disabled, selecting a metric CRS doesn't
switch the units.
I don't agree here: I don't think the user should be tied down to the
units of their input layer(s). If they want to calculate distance in
metres or feet, then they should be able to calculate distance in metres
or feet, regardless of the projection. This means that when a geographic
CRS is used, distance/area calculations need to reflect this, and return
the correct results (e.g. great circle distance).
As far as I can tell, when using QgsMeasureTool, the QgsDistanceArea never
has an ellipsoid set... is this correct?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1433#comment:7>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
