[QGIS-trac] Re: [Quantum GIS] #1680: New GRASS shell does not
display command gui
Quantum GIS
qgis at qgis.org
Mon Jul 20 18:41:56 EDT 2009
#1680: New GRASS shell does not display command gui
Reporter: cgsbob | Owner: nobody
Type: bug | Status: reopened
Priority: major: does not work as expected | Milestone: Version 1.2.0
Component: GRASS | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Comment (by cgsbob):
Replying to [comment:12 rugginoso]:
> First issue (find the grass executable) should be fixed in r11123.
Thank you for fixing the first issue. As for the second issue...I solved
that one too :) There was a problem with one of the Grass Addons (GIPE)
that messed up some of the wxpython code in grass. When I removed it, I
no longer have the QGIS GRASS Plugin crash.
So I just compiled r11123 and with the grass path solved and the grass
shell crash solved, I've been able to test further and find that there are
other problems :(
So, here are the steps I took to demonstrate the problem:[[BR]]
* Opening the grass shell displays the grass prompt[[BR]]
* Calling a command without options shows the '''old tcltk''' GUI
(GRASS_GUI not being honored)[[BR]]
* Calling a command with the options executes the command and the output
is displayed normally into the shell.[[BR]]
* Ending the grass shell by clicking the Close Button ends grass
gracefully[[BR]]
I have also tried to end the grass shell by typing CTRL-D and noticed that
the last line in ~/.grassrc6 file has been changed from:[[BR]]
GRASS_GUI: wxpython
to
GRASS_GUI: text
With this change native GRASS will start up in text mode.[[BR]]
I would think that this ticket can be closed if you can figure out a way
to find the grass command and have the QGIS GRASS Shell honor the
GRASS_GUI settings in ~/.grassrc6 and not modify it.
Thank you for adding these enhancements to the grass shell!
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1680#comment:13>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
