[QGIS-trac] [Quantum GIS] #1801: It is not possible to use Shift
 key to select multiple PostGIS tables
    Quantum GIS
    qgis at qgis.org
    Tue Jul 21 17:19:03 EDT 2009
#1801: It is not possible to use Shift key to select multiple PostGIS tables
   Reporter:  gabrimonfa        |              Owner:  nobody
       Type:  bug               |             Status:  new
   Priority:  minor: annoyance  |          Milestone:  Version 1.2.0
  Component:  GUI               |            Version:  HEAD
   Keywords:                    |   Platform_version:
   Platform:  All               |           Must_fix:  No
Status_info:  0                 |
 It should be possible, in the Add Postgis Layer to select more layers
 using Shift key and clicking only on the first one and on the last one.
 This is possible in many file browsers, so people are used to it.
 Also it will speedup things since adding a lot of layers would not require
 to individually select each of them
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1801>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
