[QGIS-trac] [Quantum GIS] #1802: problem when using a geographic
CRS after changing the central meridian
Quantum GIS
qgis at qgis.org
Wed Jul 22 09:50:44 EDT 2009
#1802: problem when using a geographic CRS after changing the central meridian
Reporter: lutra | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.2.0
Component: Projection Support | Version: HEAD
Keywords: | Platform_version:
Platform: All | Must_fix: Yes
Status_info: 0 |
Tested with both shapefiles and postgis.
How to reproduce the problem:
*) download this shapefile of the world borders
http://thematicmapping.org/downloads/TM_WORLD_BORDERS-0.3.zip
*) add it to your project
*) add a custom CRS with the following definition (for example)
"+proj=moll +lon_0=Central Meridian +x_0=False Easting +y_0=False
Northing"
*) in the project properties choose the just created CRS and activate OTFR
*) the layer shows correctly
*) now go to the CRS management and change the central meridian
"+proj=moll +lon_0=90 +x_0=False Easting +y_0=False Northing"
*) in the project properties change again to wgs84 and back again to the
custom CRS, now the shape looks weird.
*) if you zoom in enough the problem disappear
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1802>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
