[QGIS-trac] Re: [Quantum GIS] #746: more SVG symbols
Quantum GIS qgis at qgis.org
Fri Jul 24 07:58:32 EDT 2009
        Reporter:  pcavallini        |         Owner:  timlinux
            Type:  enhancement       |        Status:  new
        Priority:  minor: annoyance  |     Milestone:  Version 1.0.3
       Component:  Symbology         |       Version:  HEAD
      Resolution:                    |      Keywords:  symbols north arrow tree geology
Platform_version:                    |      Platform:  All
        Must_fix:  No                |   Status_info:  0
Comment (by matter):
 Replying to [comment:4 lutra]:
 > Adding a few symbols (I tested 30/40) is not a big problem as qgis
 doesn't slow when you open the dialog box. It is probably different if you
 add hundreds, also because it would be impossible to find what is needed.
 The solution passes by creating a selector for categories/sub categories
 and show just the symbols for that particular category.
 How did you get qGIS to "see" the symbols? I use qGIS in Linux, and When I
 add additional symbols to /usr/share/qgis/svg/ they do no show up in any
 of the dialogs in qGIS. Is there a configuration file that I need to
 change, or something in the terminal? Can you post your method for testing
 the 30/40 you mentioned? Thanks,
 Matt
Ticket URL: <https://trac.osgeo.org/qgis/ticket/746#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
