[QGIS-trac] Re: [Quantum GIS] #1806: QGIS crashes WAY too much on
Windows platforms
Quantum GIS
qgis at qgis.org
Sun Jul 26 06:19:53 EDT 2009
#1806: QGIS crashes WAY too much on Windows platforms
Reporter: kumba | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.2.0
Component: MapCanvas | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: Windows
Must_fix: Yes | Status_info: 0
Comment (by lutra):
PS
a recent thread in the grass-user mailing list remembered me (that I'm not
used to 64 bit o.s./applications) that using a 32 bit application on 64
bit o.s. can be source of (many) problems. I guess that the available qgis
binaries are not optimized for 64 bit windows.
If you compile the source code on 64 bit linux systems, qgis works fine,
so you may want to try compile qgis on your machine; is not that easy as
under linux but is possible and also documented.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1806#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
