[QGIS-trac] Re: [Quantum GIS] #1637: Legend Window;
for drag-and-drop-actions, expand layer-group only after short delay
Quantum GIS
qgis at qgis.org
Sun Jul 26 12:41:26 EDT 2009
#1637: Legend Window; for drag-and-drop-actions, expand layer-group only after
short delay
Reporter: paull | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.2.0
Component: Map Legend | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: All
Must_fix: No | Status_info: 0
Changes (by kumba):
* priority: minor: annoyance => major: does not work as expected
* type: enhancement => bug
Comment:
To the original reporter, a trick I use to get around this, is create a
"tmp" group folder, and when needing to organize your layers, move
anything to be moved into the "tmp" folder. Then collapse and move the
"Tmp" folder around instead to the point where you need specific layers,
then move them out. Kind of like a shopping cart in a grocery store
thing.
Per my duplicate bug of #1808, you have to drag stuff slowly, or you will
cause the sequencing in the layer order to get muddled up, as QGIS will
randomly move items to other areas in the stack.
Flagging more as a bug, because while one indicates an enhancement, the
disordering of the stack if you move items too fast highlights a flaw in
how QGIS is handling some actions. It behaves better if you disable
rendering while moving the folders, but even then, if you go too fast,
items still "jump" around.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1637#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
