[QGIS-trac] Re: [Quantum GIS] #1616: v.kernel and r.surf.fractal overwriting and not showing results
Quantum GIS qgis at qgis.org
Thu Jun 11 03:15:14 EDT 2009
        Reporter:  pcav                             |         Owner:  nobody
            Type:  bug                              |        Status:  new
        Priority:  minor: annoyance or enhancement  |     Milestone:  Version 1.0.3
       Component:  GRASS                            |       Version:  HEAD
      Resolution:                                   |      Keywords:
Platform_version:                                   |      Platform:  All
        Must_fix:  No                               |   Status_info:  0
Comment (by hamish):
 Replying to [comment:4 pcav]:
 > Thanks Hamish. So I assume r.surf.fractal is fixed in grass64rc>=4,
 right?
 It should be fixed since 6.4.0RC1 (Xmas 2008).
 Does it still fail with the latest QGIS build?
 > Would it be possible to fix in the same way also v.kernel,
 > perhaps before grass64 final?
 v.kernel is a bit more tricky because of the funky way it reuses the same
 option for both raster and vector output map names. I don't think it is
 too hard to manually code around that (probably can reuse some code from
 other modules) but someone else will have to do it -- I'm stretched rather
 thin with my "real-life" job right now, and that has to take precedence.
 regards,
 Hamish
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1616#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
