[QGIS-trac] [Quantum GIS] #1735: cmake error caused by recent GRASS Plugin changes.
Quantum GIS qgis at qgis.org
Mon Jun 15 01:36:33 EDT 2009
   Reporter:  cgsbob                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Build/Install                     |            Version:  HEAD
   Keywords:  GRASS module reorganize           |   Platform_version:
   Platform:  Debian                            |           Must_fix:  No
Status_info:  0                                 |
 When I compile QGIS I get this error:
 CMake Error at src/plugins/grass/CMakeLists.txt:2 (SUBDIRS):
    subdirs Incorrect SUBDIRS command.  Directory: modules-6.5 does not
 exists.
 With a little research, I notice that the grass plugin module directory
 has been reorganized.  I see that the changes make at
 [http://trac.osgeo.org/qgis/changeset?new=trunk%2Fqgis%2Fsrc%2Fplugins%2Fgrass%2FCMakeLists.txt%4010908&old=trunk%2Fqgis%2Fsrc%2Fplugins%2Fgrass%2FCMakeLists.txt%4010893]
 is not compatible with grass svn.
 As a temporarily fixed, I did this:
 ln -s /home/bobm/src/gis/qgis_svn/build/modules-6.4
 /home/bobm/src/gis/qgis_svn/build/modules-6.5
 I'm guessing that there are differences between the modules in GRASS 6.4
 vs GRASS svn, so this is not an optimal solution.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1735>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
