[QGIS-trac] [Quantum GIS] #1738: duplicated objects in map composer
Quantum GIS
qgis at qgis.org
Mon Jun 15 12:56:20 EDT 2009
Reporter: bjpfei | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.2.0
Component: Printing | Version: HEAD
Keywords: | Platform_version:
Platform: RedHat | Must_fix: Yes
Status_info: 0 |
1.) Open a QGIS-Project A (in my case some Shape and DB-Layers) where the
map composer contains at least one map window[[BR]]
2.) Change to QGIS-Project B with Open Recent Projects. This project
should also contain at least one map window in the map composer[[BR]]
3.) Open the map composer[[BR]]
4.) Close the map composer[[BR]]
5.) Change the QGIS-Project and open Project A[[BR]]
6.) Open the map composer[[BR]]
7.) Close the map composer[[BR]]
8.) Save Project A[[BR]]
9.) If you now check the .qgs-File with a text editor you can already see
more than one composerMap. In QGIS you still see one map window[[BR]]
10.) So close QGIS[[BR]]
11.) Open QGIS and load Project A. In the map composer you can see three
map windows now.
I know this isn't a very reasonable example. But if you are working with
different projects you can easily run in these problems.[[BR]]
[[BR]]
Happens with code revision 10876
thx
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1738>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
