[QGIS-trac] Re: [Quantum GIS] #1433: measurements and scale broken
in latlon
Quantum GIS
qgis at qgis.org
Thu Jun 25 07:33:52 EDT 2009
#1433: measurements and scale broken in latlon
Reporter: msieczka | Owner: timlinux
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.2.0
Component: Projection Support | Version: HEAD
Resolution: | Keywords: scale, projections, measure line, measure area
Platform_version: | Platform: All
Must_fix: Yes | Status_info: 0
Changes (by lutra):
* keywords: => scale, projections, measure line, measure area
* owner: nobody => timlinux
* milestone: Version 1.0.3 => Version 1.2.0
Comment:
These are my latest observations on this annoying bug. Maybe a few of the
following situations doesn't make sense at all (in these cases a warning
should be issued?), maybe others are puzzling.
== a) project in wgs 84, layer with a geographic system, OTFR disabled ==
*) Map Units in Degrees: map scale seems right. Measure Line and Measure
Area Tools seems to return right values.
*) Map Units in Meters or Feet: map scale is wrong, as it seems to just
exchange the value in degrees with the value in meters/degrees (ex: 30
degrees -> 30 meters). Measure Line and Measure Area Tools return wrong
values.
== b) project in wgs 84, layer with a geographic projection, OTFR enabled
Area Tools return wrong values (several times too big).
*) Map Units in Meters: map scale is wrong. Measure Line and Measure Area
*) Map Units in Feet: map scale is wrong. Measure Line and Measure Area
Tools seems return wrong values (a few times less than supposed).
== c) project in wgs 84, layer with a projected system, OTFR disabled ==
QGIS notice you that as the project is a G.C.S. and the layer is in a
P.C.S., Measure Line and Measure Area Tools will return wrong values.
*) Map Units in Degrees: map scale is wrong. Measure Line and Measure Area
*) Map Units in Meters: map scale seems right. Measure Line and Measure
Area Tools seems to return right values, at least they are consistent with
the values returned by other tools, for example Google Earth.
== d) project in wgs 84, layer with a projected system, OTFR enabled ==
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1433#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
