[QGIS-trac] Re: [Quantum GIS] #1592: Corrdinate acpture plugin - projection selector
Quantum GIS qgis at qgis.org
Tue Mar 24 21:33:26 EDT 2009
        Reporter:  belg4mit                         |         Owner:  nobody
            Type:  bug                              |        Status:  new
        Priority:  minor: annoyance or enhancement  |     Milestone:
       Component:  Build/Install                    |       Version:  1.0.0
      Resolution:                                   |      Keywords:
Platform_version:                                   |      Platform:  Windows
        Must_fix:  No                               |   Status_info:  0
Comment (by borysiasty):
 Are you sure the layer CRS is properly declared and reprojection on the
 fly is enabled? Why not to set the project CRS to match the layer CRS?
 a) Because geographic CS work in lat/long?
 b) This is the unprojected field, unless you set it's projection. The
 field below shows the coordinates in the project CRS.
 c) The map and the project CRS shoudn't differ. If they do, you need to
 enable on-the-fly reprojection.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1592#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
