[QGIS-trac] Re: [Quantum GIS] #1680: New GRASS shell does not
display command gui
Quantum GIS
qgis at qgis.org
Wed May 6 14:00:12 EDT 2009
#1680: New GRASS shell does not display command gui
Reporter: cgsbob | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone:
Component: GRASS | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: Debian
Must_fix: No | Status_info: 0
Comment (by cgsbob):
I decided to get brave and dive into the QGIS code :-) I know...my
changes are very basic.
Anyways...I changed src/plugins/grass/qgsgrassshell.cpp so that I'm able
to get the gui when I start a GRASS command without any arguments and I
set the GIS_LOCK to the process id, so I can run GRASS' d.* commands.
Index: src/plugins/grass/qgsgrassshell.cpp
--- src/plugins/grass/qgsgrassshell.cpp (revision 10746)
+++ src/plugins/grass/qgsgrassshell.cpp (working copy)
@@ -102,10 +102,11 @@
// Set shell program enviroment variables
env << "GRASS_MESSAGE_FORMAT=";
- env << "GRASS_UI_TERM=1";
+ // env << "GRASS_UI_TERM=1";
env << "GISRC_MODE_MEMORY";
env << "PS1=GRASS > ";
env << "TERM=vt100";
+ env << "GIS_LOCK=$$";
terminal->setEnvironment(env);
// Look & Feel
Maybe I should submit a separate ticket and suggest that the GRASS Shell
should have a configuration file that would allow GRASS power users to set
up their own GRASS environment?
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1680#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
