[QGIS-trac] Re: [Quantum GIS] #1687: Measure tool is very wrong
Quantum GIS qgis at qgis.org
Tue May 12 16:36:18 EDT 2009
        Reporter:  kwilliams4                        |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:
       Component:  Build/Install                     |       Version:  1.0.0
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  Debian
        Must_fix:  No                                |   Status_info:  0
Comment (by wildintellect):
 Please double check that your layer projection definition is correctly.
 Using EPSG: 3395 which is an identical proj string (as far as I can see)
 to 54004 it works fine.
 The coordinates in your screenshot do not correspond to the correct
 location of any part of the US in the projection you specified.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1687#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
