[QGIS-trac] [Quantum GIS] #1692: Problems parsing some ArcGIS shapefiles
Quantum GIS qgis at qgis.org
Wed May 13 10:44:56 EDT 2009
   Reporter:  matter                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.0.3
  Component:  OGR Layer support                 |            Version:  HEAD
   Keywords:  Shapefile support                 |   Platform_version:
   Platform:  All                               |           Must_fix:  No
Status_info:  0                                 |
 Compatibility or parsing problems have been noted with shapefiles made or
 exported from Arc 9.x, resulting in a "xxxxxxx.shp is not a valid or
 recognized data source" error in qGis 1.0.x. The shapefiles work in Arc,
 so this may be easily solved by allowing for some error tolerance in the
 OGR library? Example shapefiles are attached.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1692>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
