[QGIS-trac] Re: [Quantum GIS] #1133: grass toolbox: option
description problems
Quantum GIS
qgis at qgis.org
Wed May 13 15:23:25 EDT 2009
#1133: grass toolbox: option description problems
Reporter: hamish | Owner: nobody
Type: defect | Status: closed
Priority: major: does not work as expected | Milestone: Version 1.0.3
Component: GRASS | Version: 0.10.0
Resolution: fixed | Keywords: grass toolbox qgm
Platform_version: Etch | Platform: Debian
Must_fix: Yes | Status_info: 0
Changes (by rblazek):
* status: new => closed
* resolution: => fixed
Comment:
Fixed in revision 10787.
1. Title / checkbox text is elided on resize.
2a. Label, if defined, is used as title, otherwise description is used. If
both label and description are defined, description is used as tooltip.
2b. I don't believe it has anything to do with label/description. Once an
option was defined for the module, the plugin required a value. I have
changed it so that if the option is not required by GRASS and the value is
empty, it is not append to parameters.
Fields combobox layout problem also fixed.
Radim
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1133#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
