[QGIS-trac] [Quantum GIS] #1704: Label buffer doesn't work in map
	units
    Quantum GIS
    qgis at qgis.org
    Tue May 19 06:20:32 EDT 2009
#1704: Label buffer doesn't work in map units
   Reporter:  bjpfei                            |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:  Version 1.2.0
  Component:  Symbology                         |            Version:  HEAD
   Keywords:                                    |   Platform_version:
   Platform:  RedHat                            |           Must_fix:  Yes
Status_info:  0                                 |
 1.) open Layer Properties[[BR]]
 2.) select labels[[BR]]
 3.) mark display labels and select the field you like[[BR]]
 4.) select buffer[[BR]]
 5.) mark buffer labels[[BR]]
 6.) select a buffer size and a buffer color[[BR]]
 7.) If you now mark "size is in map units" there is no differenct to size
 in points. Seems that the size is always in points
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1704>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
