[QGIS-trac] Re: [Quantum GIS] #1703: No possibility to change color in unique value when assigning more then one class
Quantum GIS qgis at qgis.org
Tue May 19 06:29:13 EDT 2009
class
        Reporter:  bjpfei                            |         Owner:  nobody
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.2.0
       Component:  Symbology                         |       Version:  HEAD
      Resolution:  wontfix                           |      Keywords:
Platform_version:                                    |      Platform:  RedHat
        Must_fix:  Yes                               |   Status_info:  0
Changes (by jef):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 Replying to [ticket:1703 bjpfei]:
 > - in a polygon layer you can't change the fill color for the assigned
 classes[[BR]]
 > - in a line layer you can't change outline style, outline color, fill
 style and fill color[[BR]]
 > - in a point layer you can't change outline color, outline width and
 fill color[[BR]]
 This is intentional.  If you select multiple classes you can change only
 the
 options that have a common value in all those classes.
 See also r8493
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1703#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
