[QGIS-trac] Re: [Quantum GIS] #1680: New GRASS shell does not
display command gui
Quantum GIS
qgis at qgis.org
Wed May 20 14:51:03 EDT 2009
#1680: New GRASS shell does not display command gui
Reporter: cgsbob | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone:
Component: GRASS | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: Debian
Must_fix: No | Status_info: 0
Comment (by cgsbob):
Replying to [comment:4 rugginoso]:
> I think the shell must be only a terminal, for the gui of commands, you
can use the other modules of the grass plug-in.
Do you mean the grass gui that is defined by *.qgm? What about the grass
commands that do not have a *.qgm file?
I think that most users of the shell are users who needs to access the
many parameters of a command that are hidden by the qgis-grass gui. Sure,
you can type v.generalize and answer about 20 questions before
v.generalize can start. Or you can type v.generalize in the shell and see
the grass gui for v.generalize along with all of its parameters and just
fill out the information needed. Which method would you use?
Taking away the command gui is like going back to pre grass 6 (ok, so I
exaggerate a bit here). I know with a few environment variables the grass
shell can have the command gui. So, why not do it?
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1680#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
