[QGIS-trac] [Quantum GIS] #1717: Print Composer doesn't work when raising the map object from the right side
Quantum GIS qgis at qgis.org
Wed May 27 06:21:59 EDT 2009
   Reporter:  bjpfei                                     |              Owner:  mhugent
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.2.0
  Component:  Printing                                   |            Version:  HEAD
   Keywords:                                             |   Platform_version:
   Platform:  RedHat                                     |           Must_fix:  Yes
Status_info:  0                                          |
 1.) Open the print composer[[BR]]
 2.) Click Add a new map[[BR]]
 3.) Span the map from the upper right corner or from the lower right
 corner in direction left[[BR]]
 Problem: You don't see the map object and if you make a double click in
 the area where you added  the map QGIS crashes with the following
 message:[[BR]]
 Warning: QGraphicsScene::removeItem: item 0x8727bf0's scene (0x18) is
 different from this scene (0x8492918)
 Program received signal SIGSEGV, Segmentation fault.
 [Switching to Thread -1208260384 (LWP 7829)]
 0x00000011 in ?? ()
 QGIS 1.2.0 Code revision 10829
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1717>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
