[QGIS-trac] Re: [Quantum GIS] #1211: Relative paths within QGIS
project file
Quantum GIS
qgis at qgis.org
Wed May 27 13:28:12 EDT 2009
#1211: Relative paths within QGIS project file
Reporter: springmeyer | Owner: nobody
Type: enhancement | Status: closed
Priority: minor: annoyance or enhancement | Milestone: Version 1.0.3
Component: Project Loading / Saving | Version: HEAD
Resolution: fixed | Keywords: relative path
Platform_version: | Platform: Debian
Must_fix: No | Status_info: 0
Changes (by jef):
* status: new => closed
* resolution: => fixed
Comment:
Should be fixed in r10854 for single layer file data datasources
QGIS now tries to interpret the data source name of each maplayer as
filename and if that doesn't exists tries to prepend the project files
path, if that succeeds, that filename is taken, otherwise the data source
uri is left untouched.
Obviously that'll only work if the uri actually just contains the
filename. This is true for instance for single layer OGR data sources
like shapefiles.
SVG symbol are now also looked up in the project path if everything else
fails.
Feel free to reopen, if you think this isn't sufficient or inadvisable.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1211#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
