[QGIS-trac] [Quantum GIS] #1718: Incorrect unique key
interpretation on PostGIS view - view doesn't load as expected
Quantum GIS
qgis at qgis.org
Fri May 29 17:23:51 EDT 2009
#1718: Incorrect unique key interpretation on PostGIS view - view doesn't load as
expected
Reporter: mwtoews | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.0.3
Component: Data Provider | Version: HEAD
Keywords: | Platform_version:
Platform: Windows | Must_fix: No
Status_info: 0 |
I have three tables, each with zero-to-many relations to connect from spot
(providing location) -> sample -> analysis. I would like to show the
analyses at each point using a view. But when I try to add the view to
QGIS, I get a message with a error message lecture about unique keys, and
I cannot add the view.
This bug can be reproduced using this example schema and data:
== Schema ==
CREATE TABLE spot
gid serial PRIMARY KEY NOT NULL,
geometry geometry,
id character varying(50) UNIQUE NOT NULL
CREATE TABLE sample
sid serial PRIMARY KEY NOT NULL,
identifier character varying(50),
spot_id character varying(50),
CONSTRAINT sample_spot_id_fkey FOREIGN KEY (spot_id)
REFERENCES spot (id) MATCH SIMPLE
ON UPDATE CASCADE ON DELETE NO ACTION
CREATE TABLE analysis
sample_sid integer,
parameter character varying,
result real,
CONSTRAINT analysis_sample_sid FOREIGN KEY (sample_sid)
REFERENCES sample (sid) MATCH SIMPLE
ON UPDATE NO ACTION ON DELETE CASCADE
CREATE OR REPLACE VIEW spot_analysis AS
SELECT ana.sid AS analysis_sid, spt.geometry, spt.id AS spot_id, smp.sid
AS sample_sid, ana.parameter, ana.result
FROM spot spt
JOIN sample smp ON spt.id::text = smp.spot_id::text
JOIN analysis ana ON smp.sid = ana.sample_sid;
== Data ==
INSERT INTO geometry_columns(f_table_catalog, f_table_schema,
f_table_name, f_geometry_column, coord_dimension, srid, "type")
VALUES ('','','spot','geometry',2,-1,'POINT');
VALUES ('','','spot_analysis','geometry',2,-1,'POINT');
INSERT INTO spot (geometry, id) VALUES
('0101000000000000000000F03F000000000000F03F', 'spot a');
('0101000000000000000000F03F0000000000000040', 'spot b');
INSERT INTO sample (identifier, spot_id) VALUES ('samp 1', 'spot a');
INSERT INTO sample (identifier, spot_id) VALUES ('samp 2', 'spot b');
INSERT INTO sample (identifier, spot_id) VALUES ('samp 3', 'spot a');
INSERT INTO sample (identifier, spot_id) VALUES ('samp 4', 'spot b');
INSERT INTO analysis (sample_sid, parameter, result) VALUES (1, 'foo',
3.4);
INSERT INTO analysis (sample_sid, parameter, result) VALUES (1, 'bla',
4.1);
INSERT INTO analysis (sample_sid, parameter, result) VALUES (2, 'foo',
3.0);
INSERT INTO analysis (sample_sid, parameter, result) VALUES (2, 'lol',
54.2);
INSERT INTO analysis (sample_sid, parameter, result) VALUES (3, 'lol',
65.2);
INSERT INTO analysis (sample_sid, parameter, result) VALUES (3, 'foo',
2.0);
== Description of behaviour ==
Here is the full text of the error message shown after trying to add the
PostGIS vector "spot_analysis":
'''No suitable key column in view'''
* The view 'public.spot_analysis' has no column suitable for use as a
unique key.
* Qgis requires that the view has a column that can be used as a unique
key. Such a column should be derived from a table column of type int4 and
be a primary key, have a unique constraint on it, or be a PostgreSQL oid
column. To improve performance the column should also be indexed.
* The view you selected has the following columns, none of which satisfy
the above conditions:
* 'geometry' derives from 'public.spot.geometry' and is not suitable
(type is geometry) and does not have a suitable constraint)
* 'id' derives from 'public.spot.id' and is not suitable (type is
varchar) and has a suitable constraint)
* 'parameter' derives from 'public.analysis.parameter' and is not
suitable (type is varchar) and does not have a suitable constraint)
* 'result' derives from 'public.analysis.result' and is not suitable
(type is float4) and does not have a suitable constraint)
* 'sample_sid' derives from 'public.analysis.sample_sid' and is not
suitable (type is int4) and does not have a suitable constraint)
* 'sid' derives from 'public.analysis.sid' and is suitable.
* 'spot_id' derives from 'public.sample.spot_id' and is not suitable
* Note: 'sid' initially appeared suitable but does not contain unique
data, so is not suitable.
This analysis is a bit off. It references column names used from the
original tables used to construct the view. In this case, I have column
names "sid" in sample and analysis. I routinely use similar views that
stop at the sample join, a case where there is only one column named "sid"
in the mix. This problem appears when several "sid" columns exist in the
relations.
The analysis_sid key in the view is unique, and will always be unique
given the constraints and use of joins. Here is what the data look like
(all columns except geometry):
||analysis_sid||spot_id||sample_sid||parameter||result||
||1||spot a||1||foo||3.4||
||2||spot a||1||bla||4.1||
||3||spot b||2||foo||3||
||4||spot b||2||lol||54.2||
||5||spot a||3||lol||65.2||
||6||spot a||3||foo||2||
I can reproduce the behaviour with QGIS 1.0.2 and 1.2.0 via OSGeo4W. I've
tried this on different PostGIS servers (versions/platforms), so I'm
pretty confident PostGIS has nothing to do with it.
This may be related to #1535
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1718>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
