[QGIS-trac] [Quantum GIS] #2054: OSM plugin: tags/values not deleted on upload
Quantum GIS qgis at qgis.org
Fri Nov 6 10:45:44 EST 2009
   Reporter:  dankarran                         |              Owner:  nobody
       Type:  bug                               |             Status:  new
   Priority:  major: does not work as expected  |          Milestone:
  Component:  Build/Install                     |            Version:  1.3.0
   Keywords:  osm                               |   Platform_version:
   Platform:  OS X                              |           Must_fix:  No
Status_info:  0                                 |
 When a tag is removed from a node in OSM and then uploaded, the uploader
 thinks there is a change to be made, and a new version of the OSM node is
 created, but the tag you deleted in QGIS does not get removed from the OSM
 node.
 Also related, if you add a tag through QGIS, then remove it, and upload
 your changes, the tag still gets added to the OSM node.
 See, e.g. http://www.openstreetmap.org/browse/node/283515072 where I added
 the addr:city tag by accident, removed it in QGIS and added an operator
 tag (v3 of OSM node). I subsequently tried to remove the operator tag
 (v4).
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2054>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
