[QGIS-trac] [Quantum GIS] #2068: PostGIS attribute table annoymance
Quantum GIS qgis at qgis.org
Sun Nov 8 11:19:41 EST 2009
   Reporter:  imincik1          |              Owner:  nobody
       Type:  bug               |             Status:  new
   Priority:  minor: annoyance  |          Milestone:
  Component:  Digitising        |            Version:  HEAD
   Keywords:                    |   Platform_version:
   Platform:  All               |           Must_fix:  No
Status_info:  0                 |
 After editing and saving PostGIS attribute data using 'attribute table',
 edited record is moving at the and of attribute table with no respect to
 column sort order. Sometimes also during editing records are resorting  in
 unpleasant order. This behavior makes user confusing, he/she can think
 that edited data has disappeared.
 Try:
 1. Open 'attribute table' of some PostGIS layer in editing mode.
 2. Sort rows by column 'gid'.
 3. Edit some attribute value (not gid), for example row with gid 5.
 Sometimes also at this point, records are reordered.
 4. Save table. At this point, all changed rows are usually moved at the
 bottom of attribute table, no matter if I sort table by gid (which is not
 changed).
 Note:
 It seams that this behavior is getting worse when table is edited and
 saved multiple times.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2068>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
