[QGIS-trac] [Quantum GIS] #2089: Buffer produces incorrect results
Quantum GIS
qgis at qgis.org
Fri Nov 13 10:49:00 EST 2009
Reporter: jaanvajakas | Owner: borysiasty
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone:
Component: Python plugins and bindings | Version: 1.3.0
Keywords: | Platform_version:
Platform: Windows | Must_fix: No
Status_info: 0 |
To reproduce:
1. create a new project in QGIS,
2. add layer kirdem2.epg4326.shp using Layers -> Add vector layer...,
3. Tools -> Geoprocessing tools -> Buffer(s), set buffer distance to
-0.0003, choose output file, click OK
Expected result: an inner buffer of the polygons in platte carree distance
(not real distance, as interpreting degrees as meters would be ambiguous)
Actual result: certainly not a buffer neither in platte carree distance
nor in real geodetic distance nor any other projection. In some places,
the buffer exceeds the original polygon border (see qgis_buffer_bug1.png);
in some places, the buffer has "pixel artifacts" (qgis_buffer_bug1.png);
some islands are missing altogether (qgis_buffer_bug2.png).
The input data kirdem2.epg4326.shp is part of the publicly available
dataset '01.09.2009a. asustusüksus SHP' (zip - 13,65 MB, 6.11.2009 ) on
http://www.maaamet.ee/index.php?lang_id=1&page_id=272&menu_id=0
(I cut a small part out and converted to EPSG:4326 using QGIS).
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2089>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
