[QGIS-trac] Re: [Quantum GIS] #2001: Postgis Manager notes for enhancements/bug fixes
Quantum GIS qgis at qgis.org
Sun Nov 15 11:31:42 EST 2009
        Reporter:  lutra                             |         Owner:  wonder
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Python plugins and bindings       |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Comment (by lutra):
 a few things have been fixed. This is what still remains (they still are
 just suggestions). I made things a little more clear/detailed if compared
 with the ticket description.
 *) feature: allow multiple load from more than one shapefile at one time
 *) In a postgis layer if I add/edit a column with the "postgis manager",
 the attribute table is not immediately updated, as I have to reload the
 layer to see the changes. This doesn't happens if the column is added
 trough "Properties -> Attributes".
 *) If I delete a postgis column with the "postgis manager" and the I open
 the attributes table I only see "ERROR" as values. If I reload the layer
 everything seems fine.
 *) bug: when adding/editing a column I get always an error if I try to
 define the length of the field. It seems that doesn't happens just with
 the "char" data type.
 I see that "can be null" checkbox is selected by default, nevertheless I
 suggest that with datatypes that "cannot be null" to make the checkbox not
 active to avoid people uncheck it.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2001#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
