[QGIS-trac] Re: [Quantum GIS] #2092: fTools export/add geometry
tool should use source dataset CRS as target dataset CRS
Quantum GIS
qgis at qgis.org
Sun Nov 15 11:48:59 EST 2009
#2092: fTools export/add geometry tool should use source dataset CRS as target
dataset CRS
Reporter: marisn | Owner: cfarmer
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Python plugins and bindings | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: Gentoo
Must_fix: No | Status_info: 0
Comment (by cfarmer):
Replying to [ticket:2092 marisn]:
All fTools functions should use the input dataset CRS for all output
datasets. However, this means that, for example, shapefiles with no .prj
file will automatically default to the project default CRS (often WGS84).
In other words, the fTools functions ignore any manually specified CRS
info. Is it possible that this is the cause for the misspecified
shapefile? 'On the fly' option should *not* affect any fTools functions...
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2092#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
