[QGIS-trac] Re: [Quantum GIS] #2101: "identify" tool shows the "view feature form" instead of the normal identify window
Quantum GIS qgis at qgis.org
Sun Nov 15 14:58:28 EST 2009
identify window
        Reporter:  lutra                             |         Owner:  nobody
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Map Legend                        |       Version:  HEAD
      Resolution:  worksforme                        |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  Yes                               |   Status_info:  0
Comment (by jef):
 Replying to [comment:4 lutra]:
 > Ok, but what about if I want really to identify just 1 feature? If just
 the form pop ups, what about the actions, derived values and the chance to
 copy table attributes to the clipboard?
 Right, the derived values are missing.  Still the context menu was also
 available in the form and if the identify dialog is docked you also could
 see it there.
 But starting with r12130 this is configurable and by default off.  Note
 that this also affects the edit form that used to be opened automatically,
 when a single feature was identified in editing mode.  That also doesn't
 happen anymore by default.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2101#comment:5>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
