[QGIS-trac] Re: [Quantum GIS] #2092: fTools export/add geometry
tool should use source dataset CRS as target dataset CRS
Quantum GIS
qgis at qgis.org
Tue Nov 17 06:48:20 EST 2009
#2092: fTools export/add geometry tool should use source dataset CRS as target
dataset CRS
Reporter: marisn | Owner: cfarmer
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Projection Support | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: Gentoo
Must_fix: No | Status_info: 0
Changes (by cfarmer):
* component: Python plugins and bindings => Projection Support
Comment:
> fTools doesn't use input CRS for output. Target CRS is determined by
settings in "Settings" -> "Options" -> "CRS". By default (?) it will use
WGS84 as target CRS and there is no such option as "input CRS".
In actual fact, fTools does indeed use the input CRS for all outputs, so
it is possible that the issue reported here is a more generic CRS issue.
Perhaps QGIS is not properly recognizing the input CRS, and is therefore
unable to output it correctly? Would it be possible to attach the problem
shapefile to this ticket (or a more generic CRS ticket)?
Regards,
Carson
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2092#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
