[QGIS-trac] [Quantum GIS] #2108: Using Print Composer on vectors
rendered in symbology-ng mode crashes qgis.
Quantum GIS
qgis at qgis.org
Tue Nov 17 17:13:45 EST 2009
#2108: Using Print Composer on vectors rendered in symbology-ng mode crashes qgis.
Reporter: cgsbob | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.4.0
Component: Printing | Version: HEAD
Keywords: | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
Refreshing a map in Print Composer that has a vector layer rendered in
symbology-ng mode causes qgis to abort with the following message:
Warning: Qt has caught an exception thrown from an event handler. Throwing
exceptions from an event handler is not supported in Qt. You must
reimplement QApplication::notify() and catch all exceptions there.
terminate called after throwing an instance of
'pal::PalException::LayerExists*'
Aborted
I heard that currently Print Composer does not work with symbology-ng
mode, so I suggest that users should be prevented from using Print
Composer by showing a dialog that Print Composer is currently disabled in
symbology-ng mode.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2108>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
