[QGIS-trac] Re: [Quantum GIS] #2123: wrong projection information
when creating a new shapefile
Quantum GIS
qgis at qgis.org
Fri Nov 20 14:51:16 EST 2009
#2123: wrong projection information when creating a new shapefile
Reporter: cmoe | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Data Provider | Version: HEAD
Resolution: | Keywords: create shapefile;
Platform_version: | Platform: RedHat
Must_fix: Yes | Status_info: 0
Comment (by cmoe):
I stripped the problem down to the call of OGR_DS_CreateLayer of the
createEmptyDataSource method in qgsogrprovider.cpp (around linie 1525).
The reference (OGRSpatialReferenceH) we are passing seems to be ok, but
the returning layer (OGRLayerH) is missing the towgs84 part in his srs.
This seems to be intentional of ogr because OGR_DS_CreateLayer calls
morphToESRI() for the srs (line 568 in
gdal/ogr/ogrsf_frmts/shape/ogrshapedatasource.cpp). morphToESRI() removes
the towgs84 parameter.
This does not happen, if I export a postgis layer as shapefile or an
existing shapefile. But this is done in different way by the
QgsVectorFileWriter::writeAsShapefile(). qgsvectorfilewriter.cpp says at
line 397, that it doesn't strip the towgs84 parameter.
Would it be possible, to use the QgsVectorFileWriter in the
createEmptyDataSource method? According to comment qgsvectorfilewriter.cpp
we are already broken with relying on ESRI style prj-files.
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2123#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
