[QGIS-trac] Re: [Quantum GIS] #2137: Wrong ID provided to the
PostGIS on save
Quantum GIS
qgis at qgis.org
Sun Nov 22 23:56:38 EST 2009
#2137: Wrong ID provided to the PostGIS on save
Reporter: fsat | Owner: nobody
Type: bug | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Data Provider | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: Gentoo
Must_fix: No | Status_info: 0
Comment (by fsat):
Schema is attached to the ticket, to populate it with sample data just
execute the following statements.
insert into maps (ID, NAME) values(1, "map1");
insert into layers (ID, NAME, MAP_ID) values(1, "layer1", 1);
After that you can add LINESTRING layer in QGIS using view with name
"map1_l1_l" and draw a line.
And after that add POINT layer in QGIS using view with name "map1_l1_s"
and reproduce my error.
As you can see from section:
query := 'create or replace rule '|| view_name || 'i ' || '
as on insert to '|| view_name || '
do instead (
insert into layer_elements (layer_id, id, name)
values('|| lid ||', NEW.id, NEW.name);
insert into ' || le ||' (id, the_geom)
values(NEW.id, NEW.the_geom);
The ID is not calculated automaticaly, I'm using the provided one, without
defaults.
PostGIS version - 1.4.0, Postgresql version - 8.2.14, QGIS version - 1.3.0
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2137#comment:3>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
