[QGIS-trac] Re: [Quantum GIS] #2123: wrong projection information
when creating a new shapefile
Quantum GIS
qgis at qgis.org
Wed Nov 25 10:58:12 EST 2009
#2123: wrong projection information when creating a new shapefile
Reporter: cmoe | Owner: jef
Type: patch | Status: new
Priority: major: does not work as expected | Milestone: Version 1.4.0
Component: Data Provider | Version: HEAD
Resolution: | Keywords: create shapefile;
Platform_version: | Platform: RedHat
Must_fix: Yes | Status_info: 0
Changes (by mhugent):
* owner: nobody => jef
Comment:
Hi Cedric
Thank you for the patch. It might be good to test if format is shapefile,
since the method could also be used for other formats (even if this is not
the case at the moment).
Otherwise +1 for me to apply the patch.
I'm assigining the ticket to Jürgen, since he is the OGR guru in the dev
team.
Regards,
Marco
Ticket URL: <http://trac.osgeo.org/qgis/ticket/2123#comment:4>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
