[QGIS-trac] Re: [Quantum GIS] #2154: Not correctly creating (or reading) proj file for CRS for EPSG 2193
Quantum GIS qgis at qgis.org
Thu Nov 26 21:47:35 EST 2009
        Reporter:  mesajs                            |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Projection Support                |       Version:  HEAD
      Resolution:                                    |      Keywords:  CRS
Platform_version:  Vista 64                          |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Comment (by mesajs):
 Replying to [comment:1 warmerdam]:
 > I'm not clear on what actual problem you are encountering.  Is the .prj
 file you attached not one that was created by this process?[[BR]]
 [[BR]]
 Yes, it is the one created by the process. The problem is that when QGIS
 loads the shapefile, it reports (according to the layer properties dialog)
 that the CRS is user defined. But it is not user defined, it should show
 as EPSG 2193.
 I am also surprised that the .prj file has "D_unknown" as part of the
 DATUM definition. Would have expected something like NZGD2000, but then I
 don't really know what to expect here.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2154#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
