[QGIS-trac] Re: [Quantum GIS] #2154: Not correctly creating (or reading) proj file for CRS for EPSG 2193
Quantum GIS qgis at qgis.org
Sun Nov 29 11:35:48 EST 2009
        Reporter:  mesajs                            |         Owner:  nobody
            Type:  bug                               |        Status:  closed
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Projection Support                |       Version:  HEAD
      Resolution:  fixed                             |      Keywords:  CRS
Platform_version:  Vista 64                          |      Platform:  Windows
        Must_fix:  No                                |   Status_info:  0
Changes (by jef):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Hi Cédric,
 Replying to [comment:11 cmoe]:
 > thanks for the fix but one little glitch: If the extension is not
 specified in the file dialog (eg. "myshapefile" and not
 "myshapefile.shp"), the shapefile is written to the directory
 "myshapefile" but the .qpj file is written one directory above. This way,
 Qgis is not aware of the .qpj file, if I load the shapefile again with
 "add Vector Layer".
 should be fixed in r12290.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2154#comment:13>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
