[QGIS-trac] Re: [Quantum GIS] #2117: if units are in degrees, map scale is wrong in print composer
Quantum GIS qgis at qgis.org
Mon Nov 30 17:50:51 EST 2009
        Reporter:  pcav                              |         Owner:  nobody
            Type:  bug                               |        Status:  new
        Priority:  major: does not work as expected  |     Milestone:  Version 1.4.0
       Component:  Printing                          |       Version:  HEAD
      Resolution:                                    |      Keywords:
Platform_version:                                    |      Platform:  All
        Must_fix:  No                                |   Status_info:  0
Comment (by lutra):
 Hi Paolo,
 can you be more specific?
 Do you refer to the "map units per map unit" selector in the "scale bar"
 configurations of the print composer?
 If yes, I also cannot see how it can be useful (but I may be missing
 something obvious) but I otherwise see no problem at all if the the map
 units are in degrees. See attached image.
Ticket URL: <https://trac.osgeo.org/qgis/ticket/2117#comment:1>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
