[QGIS-trac] [Quantum GIS] #1964: qgis crashes after start
Quantum GIS
qgis at qgis.org
Fri Oct 2 02:38:21 EDT 2009
Reporter: torstenosgeo | Owner: nobody
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.4.0
Component: Build/Install | Version: 1.3.0
Keywords: | Platform_version: testing
Platform: Debian | Must_fix: Yes
Status_info: 0 |
Hallo,
qgis crashes after start. On the console I get the following messeges:
qgis
/usr/bin/qgis.bin: /usr/lib/libidn.so.11: no version information available
(required by /usr/lib/libcurl-gnutls.so.4)
Python support ENABLED :-)
Loaded : Click-fu (package: clickfu)
Loaded : Geocoding (package: GeoCoding)
Loaded : Geoprocessing (package: geoprocessing)
Loaded : MapSheetAutoGeoRef (package: MapSheetAutoGeoRef)
Loaded : OpenStreetMap plugin (package: osm_loader)
Loaded : Plugin Installer (package: plugin_installer)
Loaded : qgsAffine (package: qgsAffine)
SUB marker line 1
Loaded : Symbology-NG (package: symbology_ng)
Loaded : Table Manager (package: tablemanager)
Warning: Loading a file that was saved with an older version of qgis
(saved in 1.1.0-Pan (Unstable), loaded in 1.3.0-Mimas). Problems may
occur.
Debug: QGIS(19452)/ KIconCache::Private::themeDirsChanged: Theme directory
has been modified
Warning: QPainter::end: Painter not active, aborted
Warning: QPainter::begin: Cannot paint on a null pixmap
Warning: QPainter::setPen: Painter not active
Warning: QPainter::setFont: Painter not active
Warning: QPixmap::scaled: Pixmap is a null pixmap
terminate called after throwing an instance of 'QgsGrass::Exception'
what(): Incompatible library version for module. You need to rebuild
GRASS or untangle multiple installations.
Abgebrochen (Speicherabzug geschrieben)
$ qgis
SUB marker line 1
Warning: QMetaObject::connectSlotsByName: No matching signal for
on_btnHelp_clicked()
ERROR 4: `/home/torsten/Arbeit/Gis/FoEi/tk/4367059_5677239_col.tfw' not
recognised as a supported file format.
qgis.bin:
/usr/src/qgis/i386/1.3.0~gfossit20090914/qgis-1.3.0~gfossit20090914/src/app/qgsoptions.cpp:575:
void QgsOptions::getEllipsoidList(): Zusicherung »myResult == 0« nicht
erfüllt.
$ qgis
SUB marker line 1
qgis.bin:
erfüllt.
Thanks
Torsten
-- System Information:
Debian Release: squeeze/sid
APT prefers testing
APT policy: (990, 'testing'), (90, 'unstable')
Architecture: i386 (i686)
Kernel: Linux 2.6.26-2-686 (SMP w/1 CPU core)
Locale: LANG=de_DE.UTF-8, LC_CTYPE=de_DE.UTF-8 (charmap=UTF-8)
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1964>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
