[QGIS-trac] [Quantum GIS] #1966: qgis don't start after grass upgrade
Quantum GIS qgis at qgis.org
Fri Oct 2 03:14:10 EDT 2009
   Reporter:  torstenosgeo                               |              Owner:  nobody
       Type:  bug                                        |             Status:  new
   Priority:  critical: causes crash or data corruption  |          Milestone:  Version 1.4.0
  Component:  Build/Install                              |            Version:  1.1.0
   Keywords:                                             |   Platform_version:
   Platform:  Debian                                     |           Must_fix:  No
Status_info:  0                                          |
 Package: qgis
 Version: 1.1.0~gfossit20090602-1
 Severity: normal
 Hallo,
 it is temporarely possible to install grass6.4rc5 via aptitude. After the
 update it is'nt possible to start qgis because incompatibel versions.
 Please make qgis able to be running without grass or with different grass
 versions. So that it is possible to work with up to date versions of grass
 and qgis.
 Thanks
 Torsten
 -- System Information:
 Debian Release: squeeze/sid
   APT prefers testing
   APT policy: (990, 'testing'), (90, 'unstable')
 Architecture: i386 (i686)
 Kernel: Linux 2.6.26-2-686 (SMP w/1 CPU core)
 Locale: LANG=de_DE.UTF-8, LC_CTYPE=de_DE.UTF-8 (charmap=UTF-8)
 Shell: /bin/sh linked to /bin/bash
 Versions of packages qgis depends on:
 ii  libc6            2.9-4                   GNU C Library: Shared
 libraries
 ii  libexpat1        2.0.1-4                 XML parsing C library -
 runtime li
 ii  libgcc1          1:4.4.1-1               GCC support library
 ii  libgdal1-1.5.0   1.5.4-4                 Geospatial Data Abstraction
 Librar
 ii  libgeos-c1       3.1.0-1                 Geometry engine for
 Geographic Inf
 ii  libgsl0ldbl      1.12+dfsg-1             GNU Scientific Library (GSL)
 -- li
 ii  libpq5           8.4.0-2+b1              PostgreSQL C client library
 ii  libproj0         4.6.1-5                 Cartographic projection
 library
 ii  libqgis1.1.0     1.1.0~gfossit20090602-1 Quantum GIS - shared
 libraries
 ii  libqt4-network   4:4.5.2-2               Qt 4 network module
 ii  libqt4-sql       4:4.5.2-2               Qt 4 SQL module
 ii  libqt4-svg       4:4.5.2-2               Qt 4 SVG module
 ii  libqt4-xml       4:4.5.2-2               Qt 4 XML module
 ii  libqtcore4       4:4.5.2-2               Qt 4 core module
 ii  libqtgui4        4:4.5.2-2               Qt 4 GUI module
 ii  libstdc++6       4.4.1-1                 The GNU Standard C++ Library
 v3
 ii  libx11-6         2:1.2.1-1               X11 client-side library
 ii  libxext6         2:1.0.4-1               X11 miscellaneous extension
 librar
 ii  qgis-common      1.1.0~gfossit20090602-1 Quantum GIS - architecture-
 indepen
 Versions of packages qgis recommends:
 ii  python-qgis      1.1.0~gfossit20090602-1 Python bindings to Quantum
 GIS
 ii  qgis-plugin-gras 1.1.0~gfossit20090602-1 GRASS plugin for Quantum GIS
 Versions of packages qgis suggests:
 ii  gpsbabel                      1.3.6-3    GPS file conversion plus
 transfer
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1966>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
