[QGIS-trac] [Quantum GIS] #1967: no version information available
for some libs
Quantum GIS
qgis at qgis.org
Fri Oct 2 03:15:47 EDT 2009
#1967: no version information available for some libs
Reporter: torstenosgeo | Owner: rugginoso
Type: bug | Status: new
Priority: major: does not work as expected | Milestone:
Component: GRASS | Version: HEAD
Keywords: | Platform_version:
Platform: Debian | Must_fix: No
Status_info: 0 |
Package: grass
Version: 6.4.0~rc4-3
Severity: normal
Hallo,
I get the error/warning messages:
v.label: /usr/lib/libidn.so.11: no version information available (required
by /usr/lib/libcurl-gnutls.so.4)
it seems that it is possible to install incompatible programparts.
Thanks
Torsten
-- System Information:
Debian Release: squeeze/sid
APT prefers testing
APT policy: (990, 'testing'), (90, 'unstable')
Architecture: i386 (i686)
Kernel: Linux 2.6.26-2-686 (SMP w/1 CPU core)
Locale: LANG=de_DE.UTF-8, LC_CTYPE=de_DE.UTF-8 (charmap=UTF-8)
Shell: /bin/sh linked to /bin/bash
Versions of packages grass depends on:
ii gnome-terminal [x-term 2.24.3-3 The GNOME 2 terminal emulator
appl
ii konsole [x-terminal-em 4:4.2.4-1 X terminal emulator for KDE 4
ii lesstif2 1:0.95.0-2.1 OSF/Motif 2.1 implementation
relea
ii libc6 2.9-4 GNU C Library: Shared
libraries
ii libcairo2 1.8.6-2+b1 The Cairo 2D vector graphics
libra
ii libfftw3-3 3.1.2-3.1 library for computing Fast
Fourier
ii libfreetype6 2.3.9-4 FreeType 2 font engine,
shared lib
ii libgcc1 1:4.4.1-1 GCC support library
ii libgdal1-1.5.0 1.5.4-4 Geospatial Data Abstraction
Librar
ii libgl1-mesa-glx [libgl 7.0.3-7 A free implementation of the
OpenG
ii libglu1-mesa [libglu1] 7.0.3-7 The OpenGL utility library
(GLU)
ii libice6 2:1.0.5-1 X11 Inter-Client Exchange
library
ii libmysqlclient15off 5.0.51a-24 MySQL database client library
ii libncurses5 5.7+20090404-1 shared libraries for terminal
hand
ii libpng12-0 1.2.35-1 PNG library - runtime
ii libpq5 8.4.0-2+b1 PostgreSQL C client library
ii libproj0 4.6.1-5 Cartographic projection
library
ii libreadline5 5.2-4 GNU readline and history
libraries
ii libsm6 2:1.1.0-2 X11 Session Management
library
ii libsqlite3-0 3.6.17-2 SQLite 3 shared library
ii libstdc++6 4.4.1-1 The GNU Standard C++ Library
v3
ii libtiff4 3.8.2-11 Tag Image File Format (TIFF)
libra
ii libwxbase2.8-0 2.8.7.1-1.1 wxBase library (runtime) -
non-GUI
ii libwxgtk2.8-0 2.8.7.1-1.1 wxWidgets Cross-platform C++
GUI t
ii libx11-6 2:1.2.1-1 X11 client-side library
ii libxext6 2:1.0.4-1 X11 miscellaneous extension
librar
ii libxmu6 2:1.0.4-1 X11 miscellaneous utility
library
ii libxt6 1:1.0.5-3 X11 toolkit intrinsics
library
ii python2.5 2.5.4-1 An interactive high-level
object-o
ii tcl8.4 8.4.19-3 Tcl (the Tool Command
Language) v8
ii tk8.4 8.4.19-3 Tk toolkit for Tcl and X11,
v8.4 -
ii unixodbc 2.2.11-16+b1 ODBC tools libraries
ii xfce4-terminal [x-term 0.2.8-5 Xfce terminal emulator
ii xterm [x-terminal-emul 243-1 X terminal emulator
ii zlib1g 1:1.2.3.3.dfsg-13 compression library - runtime
Versions of packages grass recommends:
ii ghostscript 8.70~dfsg-2 The GPL Ghostscript
PostScript/PDF
ii python 2.5.4-2 An interactive high-level
object-o
ii python-numpy 1:1.2.1-1 Numerical Python adds a fast
array
Versions of packages grass suggests:
ii avce00 2.0.0-2 Tools for conversion of ESRI
Arcin
ii curl 7.19.5-1.1 Get a file from an HTTP,
HTTPS or
ii e00compr 1.0.1-1 a program to read/write
Arc/Info c
ii gdal-bin 1.6.2-1 Geospatial Data Abstraction
Librar
ii gnuplot 4.2.5-2 A command-line driven
interactive
ii gpsbabel 1.3.6-3 GPS file conversion plus
transfer
ii gpstrans 0.41-2 communicate with a Garmin
Global P
ii grass-doc [grass-doc] 6.4.0~rc5-2 Geographic Resources Analysis
Supp
ii proj-bin 4.6.1-5 Cartographic projection
library (t
ii python-opengl 3.0.0~c1-1 Python bindings to OpenGL
ii python-wxgtk2.8 2.8.7.1-1.1 wxWidgets Cross-platform C++
GUI t
ii wget 1.11.4-2 retrieves files from the web
ii xml2 0.4-2 Convert between XML, HTML,
CSV and
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1967>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
