[QGIS-trac] [Quantum GIS] #1974: Enable render caching where
possible
Quantum GIS
qgis at qgis.org
Mon Oct 5 09:11:00 EDT 2009
#1974: Enable render caching where possible
Reporter: timlinux | Owner: timlinux
Type: patch | Status: new
Priority: minor: annoyance | Milestone: Version 1.4.0
Component: MapCanvas | Version: HEAD
Keywords: cache performance | Platform_version:
Platform: All | Must_fix: No
Status_info: 0 |
User story 1:
Joe is reordering layers, each of which points back to a postgis database
with thousands of records. Each time he drops a layer to a new position,
he waits a long time while each layer redraws, even though the content of
the layers is the same, just being rendered in a different order.
User story 2:
Jane is changing symbology in a layer. When she clicks apply, she waits a
long time while all other layers redraw too.
User story 3:
Pete is hiding and showing layers. Each time he hides or shows a layer, he
waits a long time while the layers redraw.
The solution to this is to provide some kind of caching mechanism. The
attached patch is my first draft that addresses the above scenarios and
makes QGIS much more responsive when engaged in the activities described.
Please note the patch is a work in progress and there are some edge cases
where it does not yet behave well. In order to activate caching, tick the
checkbox for this in the rendering tab of the options panel (its disabled
by default).
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1974>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
