[QGIS-trac] Re: [Quantum GIS] #1971: print composer crashes when
adding image path
Quantum GIS
qgis at qgis.org
Wed Oct 7 08:52:51 EDT 2009
#1971: print composer crashes when adding image path
Reporter: pcav | Owner: mhugent
Type: bug | Status: new
Priority: critical: causes crash or data corruption | Milestone: Version 1.4.0
Component: Printing | Version: HEAD
Resolution: | Keywords:
Platform_version: | Platform: Debian
Must_fix: No | Status_info: 0
Comment (by mhugent):
>If I add an image to a map composer, the icon remains pressed, and
nothing happens until I click on the page
Yes, this is the same behaviour as with the other tools (add scalebar,
legend, composer map, label).
>If I try to add a directory of images (containing also othe files, QGIS
crashes:
Hm, this does not happen for me here (also if other files are in the
directory). Maybe it only happens with certain types of file? The composer
uses two qt classes (QSvgRenderer and QImageReader) to test if the files
are valid as composer pictures
>Furthermore, adding a valid path does not persiste across images (if I
add a second image, I >have to add my path again)
But if you press the file selection button, the path should be stored for
the file dialog
Ticket URL: <http://trac.osgeo.org/qgis/ticket/1971#comment:2>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac
