[QGIS-trac] Re: [Quantum GIS] #1959: Trunk build fails with sip-4.9 and PyQt-4.6
Quantum GIS qgis at qgis.org
Thu Oct 8 12:11:33 EDT 2009
        Reporter:  jctull                                     |         Owner:  nobody
            Type:  bug                                        |        Status:  closed
        Priority:  critical: causes crash or data corruption  |     Milestone:  Version 1.4.0
       Component:  Build/Install                              |       Version:  HEAD
      Resolution:  fixed                                      |      Keywords:  sip pyqt compile
Platform_version:  10.6.1                                     |      Platform:  OS X
        Must_fix:  Yes                                        |   Status_info:  0
Changes (by jef):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:7 vince]:
 > This is not OS dependent, it is caused by a change of API between SIP
 4.8 and 4.9. The version of SIP should be tested.
 looks like the patched {{{conversion.sip}}} also works with SIP 4.8.
 Applied in r11773
Ticket URL: <https://trac.osgeo.org/qgis/ticket/1959#comment:8>
Quantum GIS <http://qgis.org>
Quantum GIS is an Open Source GIS viewer/editor supporting OGR, PostGIS, and GRASS formats
More information about the QGIS-trac mailing list
